PShar30
6 years agoWant to access RAM data, from Linux running on HPS of Cyclone V
Board : cyclone V I am new to VHDL, I created a 1 port ram through IP integrator, And able to store some value in it, Now I want to access that data in Linux running on HPS using PYTHON. Is it possi...
EBERLAZARE_I_Intel
6 years agoHi,
Yes it is possible.
Were you able to boot the preloader, uboot and also into Linux?
Firstly, I recommend that you check out Rocketboards.org (Get Started) on how to boot the device and eventually run Linux on your Cyclone V SoC board.
You may also use the pre-built image here: https://rocketboards.org/foswiki/Documentation/GSRD180ReleaseNotes#Release_Contents
