13 years agoVideo and Image Processing Design Example NiosII Problem
Hello Everyone, Hope I can get your help! I'm new to NiosII and Altera in general. I am trying to follow the instructions on the Video and Image Procesing Design Example and there is a part ...
13 years agoI have the same issue with QII 12.1 64-bit for Linux.
Have you solved it? Many thanks, Michele. --- Quote Start --- Thank you very much for your response! It in deed has that part: <module name="cpu" kind="altera_nios2_qsys" version="12.1" path="cpu"> I tried changing the "path" to match the one you put but it was no good. Is there something I can do to change it? Thanks very much in advance! --- Quote End ---
