13 years agoVideo and Image Processing Design Example NiosII Problem
Hello Everyone, Hope I can get your help! I'm new to NiosII and Altera in general. I am trying to follow the instructions on the Video and Image Procesing Design Example and there is a part ...
13 years ago --- Quote Start --- I don't know if there's a problem with the .sopcinfo file or with the installation or configuration of my Nios. --- Quote End --- .sopcinfo is an XML file (ASCII text). You should be able to open it and search for the string "nios2". You ought to find a <module/> similar to this:
<module
name="nios2_qsys_0"
kind="altera_nios2_qsys"
version="12.0"
path="nios2_qsys_0">
(I believe the important part is "kind=altera_nios2" ). Does your .sopcinfo have this? If not, the problem is with your .sopcinfo and not your tools.
