TYiyu's avatar
TYiyu
8 years ago
vector_add included in the DE5a-NET BSP for OpenCL 17.1
After compiled the example source vector_add, I read the project file top.qpf into the Quartus Prime Pro 17.1 and synthesized the system. But Quartus can not generate kernel_system_mandelbrot_kernel_system.ip.
  • HRZ's avatar
    HRZ
    You are not supposed to import and synthesize OpenCL designs manually inside of Quartus. Use the standard flow provided by the OpenCL compiler itself.
  • FawazJ_Altera's avatar
    FawazJ_Altera
    Hello
    This is not supported flow.
    Follow the steps in the attached document, start with Page 16, you will see the tutorial of compiling OpenCL project.
  • TYiyu's avatar
    TYiyu
    Hi, all,
    Thanks for reply. I know the opencl compilation steps, and the system
    can be compiled and run at the FPGA board successfully. My question is
    that when I read into the compiled project file (top.qpf), which is
    generated by the opencl compilation (aoc command), into the Quartus
    Prime Pro, and synthesized it to take a look at the circuit
    architecture, the errors I mentioned occurred.
    Thanks a lot.
    Tan
