15 years ago
Using the SDRAM on the DE2-115 without NIOS, only HDL language
I am currently trying to implement a dual-port RAM in the DE2-115 evaluation board, using the 2x64 MB SDRAM chips. I do not want to use NIOS or SOPC builder at all, only using HDL language.
At first I thought that the Altera Megafunction where suppose to do it but since there was no pin assignment to do I got sceptical and then understood that is was for the memory block of the Cyclone IV chip.
Then I took a look at the datasheet of the SDRAM chip and also at the Quartus II handbook about the HDL coding style while interfering with memory modules but I am confused with all the different commands and operation that needs to be done to use the SDRAM (compared to a simple SRAM for example).
As I already lost too many times already, I am wondering if somebody knows where I can find somekind of manual/tutorial, like the following link: ftp://ftp.altera.com/up/pub/altera_material/9.1/tutorials/vhdl/de2-115/using_the_sdram.pdf but without NIOS processor as I don't want to use it.
Or in the worse case where I would need to do everything myself, is there some tips that needs to be known while using SDRAM or should I just apply "stupidly" the truth table of the SDRAM pins for the required operation (read/write)?
Thank you in advance,
Meach
    Better use small Nios and use DMA as You will still need to pass the initialization.
    --- Quote Start ---
    I'd like to revive this page. Someone might have new answers about this. I've just realized that the SDRAM in DE2-115 is not a DDR one so none in the MegaWizard IP works.
    In this tutorial, the SDRAM was used along side NIOS. I don't want to use NIOS like the thread starter. ftp://ftp.altera.com/up/pub/altera_material/12.0/tutorials/vhdl/de2-115/using_the_sdram.pdf
    Any insights on how to implement the SDRAM without NIOS?
    In Chapter 9: Implementing and Parameterizing Memory IP 9–3 Design Flow of this handbook (http://www.altera.com/literature/hb/external-memory/emi_plan.pdf), it showed two possible ways to generate the IP. One using the Qsys and the other using the MegaWizard. Can someone share their knowledge on how to create a complete IP of the SDRAM Controller using Qsys with AVALON interface as the controlling component?
    --- Quote End ---
    I am trying to do the same for distributed processing. The ISSI chip on the DE2-115 is Single Data Rate (SDR) SDRAM. There is an SDRAM Controller available from the IP Catalog under the following in Qsys:
    Memory Interfaces with ALTMEMPHY>SDRAM>SDRAM Controller.
    You would then export the signals to the external RAM chip and connect the in/outputs in your toplevel VHDL or Verilog file. To interface with the chip, you would have to adhere to the Avalon-Memory Mapped interface specification, which is standard and would be the same way you would interact with on-chip memory (See the Avalon Interface Specificaitons document or look for some examples).
    One thing that you must remember is that the SDRAM chip clock DRAM_CLK leads the system clock CLK_50 by 3 nanoseconds on the DE2-115. You may have to include a Phase Lock Loop (PLL) module to adjust for the offset. This is described when interfacing with the Nios II and should hold for custom logic as well due to off-chip latency. Hope that works!
    The document "Using the SDRAM on Altera’sDE2-115 Board" has that timing detail as well as an example with the Nios II as reference.
    (please rep if you find helpful =)
