15 years agoUsing the SDRAM on the DE2-115 without NIOS, only HDL language
I am currently trying to implement a dual-port RAM in the DE2-115 evaluation board, using the 2x64 MB SDRAM chips. I do not want to use NIOS or SOPC builder at all, only using HDL language. At first I thought that the Altera Megafunction where suppose to do it but since there was no pin assignment to do I got sceptical and then understood that is was for the memory block of the Cyclone IV chip. Then I took a look at the datasheet of the SDRAM chip and also at the Quartus II handbook about the HDL coding style while interfering with memory modules but I am confused with all the different commands and operation that needs to be done to use the SDRAM (compared to a simple SRAM for example). As I already lost too many times already, I am wondering if somebody knows where I can find somekind of manual/tutorial, like the following link: ftp://ftp.altera.com/up/pub/altera_material/9.1/tutorials/vhdl/de2-115/using_the_sdram.pdf but without NIOS processor as I don't want to use it. Or in the worse case where I would need to do everything myself, is there some tips that needs to be known while using SDRAM or should I just apply "stupidly" the truth table of the SDRAM pins for the required operation (read/write)? Thank you in advance, Meach
