15 years agoUsing the SDRAM on the DE2-115 without NIOS, only HDL language
Hello, I am currently trying to implement a dual-port RAM in the DE2-115 evaluation board, using the 2x64 MB SDRAM chips. I do not want to use NIOS or SOPC builder at all, only using HDL langua...
14 years agoMeach,
Which core did you end up using for your project? Did you use an Altera core, write one yourself, or use something else? Opencores?
