15 years agoUsing the SDRAM on the DE2-115 without NIOS, only HDL language
Hello, I am currently trying to implement a dual-port RAM in the DE2-115 evaluation board, using the 2x64 MB SDRAM chips. I do not want to use NIOS or SOPC builder at all, only using HDL langua...
15 years agoHi there,
I'm currently stucked in the same problem, I'm trying to use the SDRAM of my DE2-115. my first try has been reading datasheet and doing my own controller, but is a mess. I understand the way sdram works, but I'm geting mad with the vhdl programation, is there a vhdl example or tutorial? Also, if use megacore, wich one is the one I need? because i tried two of them and i was unsuccessful tu make it work, I discard all the DDR (is this ok?) the issi sdram isn't a DDR Thanks, Guillermo
