15 years agoUsing the SDRAM on the DE2-115 without NIOS, only HDL language
Hello, I am currently trying to implement a dual-port RAM in the DE2-115 evaluation board, using the 2x64 MB SDRAM chips. I do not want to use NIOS or SOPC builder at all, only using HDL langua...
13 years agoI'd like to revive this page. Someone might have new answers about this. I've just realized that the SDRAM in DE2-115 is not a DDR one so none in the MegaWizard IP works.
In this tutorial, the SDRAM was used along side NIOS. I don't want to use NIOS like the thread starter. ftp://ftp.altera.com/up/pub/altera_material/12.0/tutorials/vhdl/de2-115/using_the_sdram.pdf Any insights on how to implement the SDRAM without NIOS? In Chapter 9: Implementing and Parameterizing Memory IP 9–3 Design Flow of this handbook (http://www.altera.com/literature/hb/external-memory/emi_plan.pdf), it showed two possible ways to generate the IP. One using the Qsys and the other using the MegaWizard. Can someone share their knowledge on how to create a complete IP of the SDRAM Controller using Qsys with AVALON interface as the controlling component?
