SKon1
6 years agoUsing the -add_delay switch
Hello, I'm setting an output delays on DDR interface for a signal named "valid" relative to a clock named "clock" as follows: set_output_delay -clock clock -max -0.9 [get_ports {valid}] set_outpu...
KhaiChein_Y_Intel
6 years agoHi,
You may refer to https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/an/an433.pdf (Example 2):
set_output_delay -clock [get_clocks output_clk] -max 2 [get_ports data_out] set_output_delay -clock [get_clocks output_clk] -min -1 [get_ports data_out] -add_delay
set_output_delay -clock [get_clocks output_clk] -max 2 -clock_fall [get_ports data_out] -add_delay
set_output_delay -clock [get_clocks output_clk] -min -1 -clock_fall [get_ports data_out] -add_delay
KhaiY
