9 years agoUsing Oscilloscope instead of LEDs for output signals.
Hello everyone! Is there a way to show an output signal from a DE2 board on an oscilloscope instead of on an LED??? I have created a simple project using Block Diagram/Schematics tool of Quartus II a...
9 years agoHello Hozan 677
To connect your GPIO pins in a safe way (prevent shortcuts) with a probe, the following article can be very usefull: https://www.aliexpress.com/item-img/40pcs-dupont-cable-jumper-wire-dupont-line-male-to-female-dupont-line-2-54mm-20cm-1p/32481062593.html?spm=2114.10010108.1000017.2.ncfieo The individual feeders/wires of the ribbon cable can be separated easily and the small female plugs fit nicely over the gpio pins. The male plugs of these cables can be used to clamp the probe of the scope on. Good luck johi.
