9 years agoUsing Oscilloscope instead of LEDs for output signals.
Hello everyone! Is there a way to show an output signal from a DE2 board on an oscilloscope instead of on an LED??? I have created a simple project using Block Diagram/Schematics tool of Quartus II a...
9 years agouse some IO pins and hookup the probes. Check the datasheet to find which pins are 5v 3v and ground, as well as the o es you can use for your signal
