11 years agoUsing Max V Dev Kit board for custom tool - question
At work I need a custom interface for logic analyzing a proprietary 4-wire serial I/O bus, basically to convert the serial bytes to parallel and output them to a logic analyzer for trace and debug. I...
11 years agohie jawjatek,
welcome to the forum! =P i'm new too! Not sure how experienced you are with Altera board, so i guess you could always start with the Ref Designs here: https://www.altera.com/products/reference-designs/all-reference-designs.html Else, like you said, if you have a pretty good base design, building on top of that is a good idea. But "copy project" is pretty messy at times, based on my experience. This might not make sense to you but what i usually do is: 1. create a new project 2. save out the IPs/bdfs from the base design and attach them to my new project 3. just recreate the design manually but referencing the existing project + adding the IPs/bdfs from the base project i guess i prefer doing (almost) from scratch to setup e'thing =) good luck!
