12 years ago
Using HPS_KEY and HPS_LED in FPGA via LOAN IO in DE1-SoC
I am using DE1-SoC with Quartus II v13.1 and v14.0.
I want to use GPIO attached to HPS from the FPGA side.
I referred to some related documents and forum topics:
how can i implement hps loan io and confirm timing? (http://www.altera.com/support/kdb/solutions/rd04132014_234.html)
an 702: interfacing a usb phy to the hard processor system usb 2.0 otg controller (http://www.altera.com/literature/an/an702.pdf)
instantiating the hps component (http://www.altera.com/literature/hb/arria-v/av_54027.pdf#page=10)
accessing hps pins (http://www.alteraforum.com/forum/showthread.php?t=41652)
how to let fpga get access to hps pins (http://www.alteraforum.com/forum/showthread.php?t=44486)
Then I added some LOAN IO code to GHRD source.
Its main part is as follows and the exact code is attached.
assign loan_io_oe = 1'b1; // HPS_LED is in output mode
assign loan_io_out = loan_io_in; // HPS_LED <- HPS_KEY
assign LEDR = loan_io_in; // LEDR <- HPS_KEY
Now my FPGA can access an input pin (HPS_KEY) attached to HPS.
However, it can not access an output pin (HPS_LED).
When I program the FPGA, LEDR[0] turns on and HPS_LED is off.
Pushing the HPS_KEY turns LEDR[0] off, but HPS_LED keeps off.
HPS_LED is not broken as I tested using hps_gpio Demo project.
I also tested both 1 and 0 of USER_IO_DIR bit for HPS_LED,
which controls HPS GPIO direction.
My question is how I can control LOAN IO as an output pin.
What I exactly did is:
* Copy de1_soc_GHRD project in V.1.2.0 SystemCD as a new project.
* Double click hps_0 in Qsys.
* Disable GPIO53/54 buttons and enable LOANIO53/54 buttons in Periferals Mux Table in Periferal Pins tab.
* Export h2f_loan_io as hps_0_h2f_loan_io.
* Perform Generate HDL and Finish.
* Modify ghrd_top.v as attached patch.
* Start "Analysis & Synthesis".
* Assign 3.3-V LVTTL to LOANIO53/54 pins in Pin Planner.
* Start Compilation.
Thank you very much and Regards,
