14 years agoUsing GPIO on modern evaluation kits
I'd like to to use the GPIOs on evaluation kit/ development board. My project require connecting them back into the FPGA. Is there a possibility to solder/connect those pins on ? I consider using dk-dev-2agx125n (dev. board for arria ii gx),and it is not clear how to connect to those pins. I also would like to evaluate FPGA performance with different core voltages. Is there elegant way to do it on evaluation boards? Thanks :)
1 Reply
there should be an HSMC to 40 pin header daughter card that comes with the dev kit
how do you plan to evaluate performance with different core voltages?
