Using EMAC hps peripheral in FPGA mode
I'm evaluating Cyclone V customized board. Using EMAC hps peripheral in FPGA mii mode, a MII to RMII converter to drive RMII Phy at 100Mbps.
Phy is being detected but could not establish connectivity.
Need help to understand the issue.
snehal_p
- tehjingy_Altera
Hi Snehal
Could you try connecting the device to a network and try getting a dynamic IP?
Jingyang, Teh
- snehal_p
Contributor
Hello Jingyang,
PFA bootlog, connecting the EMAC to a network and issued the dhcp command also assigned IP manually, but unfortunately, it is still not working as expected & no response or connectivity established.
snehal_p
- tehjingy_Altera
Hi Snehal
Thanks for the logs.
I would require some more time to take a look at this issue as I am discussing this with our technical specialist.
Jingyang, Teh
- tehjingy_Altera
Hi Snehal
Going through the device tree we found that one of the field in the device tree is incorrect.
Could you try changing that and test it again please.
In line 1031
sysmgr: system-manager@0xffd08000 {
compatible = "altr,sysmgr", "syscon";
reg = <0xffd08000 0x00004000>;
The changes should be "compatible = "altr,sys-mgr", "syscon";"
Jingyang, Teh
- tehjingy_Altera
Hi
Jingyang, Teh
