Gyud0
6 years agoUsing Altera reserved I/O pins by an Altera IP
hey, I'm using Altera IP that requires I/O pins that also reserved for Altera so I got Fitter's Quartos errors such as: Error(176310): can't place multiple pins assigned to pin location Pin_E2 (IOP...
ShafiqY_Intel
6 years agoHi Gyud0,
Error(176310) because of you assigned two or more pins to the specified location, but the Fitter cannot place all the pins in that location.
Below is solution you can try:
If the conflict arises from location assignments in the current project, delete or change the location assignment of one or more of the pins. If the pin location assignments come from one or more imported design partitions, delete or change the location assignment (possibly using the Virtual Pin assignments) in the lower-level designs, re-generate the Quartus Prime Exported Partition File(s) (.qxp) , and re-import.
