10 years agousing 7 segment display in DE1 soc
I am trying to use the 7 segment display of board de1 soc. I am using linux image in an SD memory card. I could compile successful the hello.c, that has this code: int main(int argc, char...
10 years agoi. Is it possible of you to tell which linux image you use?
ii. Did you add SEG module in Qsys? iii. make sure the avalon bus to linux address mapping is corret. iv. Did you update the rbf file?
