M3511
5 years agoUsing 644.53125 MHz clock on Stratix V Dev Board
I need to use the 644.53125 MHz clock on the Stratix V development board. Do I just need to connect to pins AB34/AB35? Or do I also need to set it to that particular frequency? Not completely ...
- 5 years ago
Hi
Thanks for update. Based on my understanding, dev kit board already pre-programed with certain default clock frequency value. The default clock frequency value can be checked via either user guide doc or from schematic. U46 CLK1 output 644.5313MHz by default this mean clock generator chip (for example U46) will generate clk1 output = 644.5313MHz directly. No need to set anything.
AR_A_Intel
4 years agoHi
Based on m understanding, it shouldn’t matter and it depends on whether you using it with Intel FPGA IP or your own IP.
If you are using Intel FPGA IP then you could check the IP user guide doc for further clarification.
