M3511's avatar
M3511
5 years ago
Using 644.53125 MHz clock on Stratix V Dev Board
Hi, I need to use the 644.53125 MHz clock on the Stratix V development board. Do I just need to connect to pins AB34/AB35? Or do I also need to set it to that particular frequency? Not completely ...
  • AR_A_Intel's avatar
    5 years ago
    Hi
    Thanks for update. Based on my understanding, dev kit board already pre-programed with certain default clock frequency value. The default clock frequency value can be checked via either user guide doc or from schematic. U46 CLK1 output 644.5313MHz by default this mean clock generator chip (for example U46) will generate clk1 output = 644.5313MHz directly. No need to set anything.
