User LEDs 2 - 4 on NEEK, Cyclone III
NEEK Cyclone III
cycloneIII_3c25_niosII_standard_sopc.sopcinfo How do I blink LEDs 2 - 4? Below code blinks LED1. Also, any references to documents where I could have figured this out by my self would be extremely useful. Thanks.# include <stdio.h># include "system.h"# include "altera_avalon_pio_regs.h"
int main()
printf("Hello from Nios II!\n");
int count = 0;
int delay;
while(1)
IOWR_ALTERA_AVALON_PIO_DATA(LED_PIO_BASE, count & 0x01);
delay = 0;
while(delay < 2000000)
delay++;
count++;
return 0;
The PIO port is connected to the LEDS on the board. Each bit in the PIO port corresponds to an LED. So if you change the one line to read:
You should get two leds blinking ... oh the excitement. :) Amazing how rewarding the blinking of a little light can be. JakeIOWR_ALTERA_AVALON_PIO_DATA(LED_PIO_BASE, count & 0x03); - Altera_Forum
Thanks for the reply.
Ok. At least I'm not going crazy... I tried that prior to posting and only LED 1 blinks. I thought maybe I was doing something wrong. Here's my system.h. The DATA_WIDTH field looks wrong to me./* * led_pio configuration * */ # define ALT_MODULE_CLASS_led_pio altera_avalon_pio# define LED_PIO_BASE 0x8000190# define LED_PIO_BIT_CLEARING_EDGE_REGISTER 0# define LED_PIO_CAPTURE 0# define LED_PIO_DATA_WIDTH 2# define LED_PIO_DO_TEST_BENCH_WIRING 0# define LED_PIO_DRIVEN_SIM_VALUE 0x0# define LED_PIO_EDGE_TYPE "NONE"# define LED_PIO_FREQ 60000000u# define LED_PIO_HAS_IN 0# define LED_PIO_HAS_OUT 1# define LED_PIO_HAS_TRI 0# define LED_PIO_IRQ -1# define LED_PIO_IRQ_INTERRUPT_CONTROLLER_ID -1# define LED_PIO_IRQ_TYPE "NONE"# define LED_PIO_NAME "/dev/led_pio"# define LED_PIO_RESET_VALUE 0x0# define LED_PIO_SPAN 16# define LED_PIO_TYPE "altera_avalon_pio" - Altera_Forum
I did look at the example project that I have (which is a bit old) and it seems the led pin assignments are a bit goofy.
LED0 is P13 (correct) LED1 is T1 (not correct, goes to HSMC connector) should be N12 LED2 is N12 - should be P12 LED3 is N9 (correct). If memory serves, I believe they did this because of some conflict with the DDR pins (too many pins toggling near a VREF pin). Jake - Altera_Forum
How does that translate to the right call to get the other LEDs to light?
IOWR_ALTERA_AVALON_PIO_DATA - Altera_Forum
You have to change the pin assignment in Quartus. You can open the Pin Planner and find which pins the "top_led" signals are connected to. But it still doesn't explain why the other 2 LEDs aren't lighting up.
I have a NEEK at home. I'll have to look at it later tonight. Jake - Altera_Forum
Who can help me? I now have a ISP1362's IP core, but the version too old, in the Quartus9.0 can not be used. Who have the latest version of the ISP1362's IP core? Can sent me a? [email protected]
