16 years agoUser LEDs 2 - 4 on NEEK, Cyclone III
NEEK Cyclone III cycloneIII_3c25_niosII_standard_sopc.sopcinfo How do I blink LEDs 2 - 4? Below code blinks LED1. Also, any references to documents where I could have figured this out ...
16 years agoI did look at the example project that I have (which is a bit old) and it seems the led pin assignments are a bit goofy.
LED0 is P13 (correct) LED1 is T1 (not correct, goes to HSMC connector) should be N12 LED2 is N12 - should be P12 LED3 is N9 (correct). If memory serves, I believe they did this because of some conflict with the DDR pins (too many pins toggling near a VREF pin). Jake
