Use Marvell 88E1111 PHY without using TSE IP
May I know are you trying to look for free IP since you brought up IP suite license concern ?
The other option that I can think of is to use "transceiver NativePHY Intel Stratix V FPGA IP" or "ALTLVDS_RX or ALTLVDS_TX"
- However, these are not Ethernet PHY IP
- It's just a skeleton PHY IP that user can customize and build whatever PHY protocol. For instance, Ethernet protocol
- I think these are free IP but pls confirm with your local distributor
dlim
- DanielGP5 years ago
Hi, again!
Thank you for the fast response.
Yes, I am looking for a way to use the Ethernet interface without requiring an additional license. I thought that the license for the TSE IP was due to the MAC (which is soft-logic) and not due to the PCS/PMA (which is hard-logic) as shown below:
I have already tried to use the Transceiver Native PHY Intel Stratix V FPGA IP. In your design store, there is this great example for Arria 10, however, as far as I understood, it seems that the serial connection only supports high-speed ethernet using SFP+ ports instead of RJ45. I need to use the RJ45 interface from the Stratix V (which is the one connected to the 88E1111 chip).
What I need to understand is how to use the hard IPs that TSE uses for PCS/PMA as I already have a MAC IP. For instance, for the 10Gb connection, we can use the 10GBASE-R PHY IP for free and then develop our own MAC IP using XGMII interface. For 100M/1G, we developed the MAC IP using GMII interface and we need the PHY IP for interfacing the 88E1111 via SGMII.
Am I missing something?
