14 years agoUSB blaster installation problems in W7 64bit
:confused: How can I install USB blaster in Windows 7 64 bit? it just can´t install the drivers correctly, every time I connect the tool to my PC it tries to install the already installed drive...
14 years ago --- Quote Start --- People who want to avoid installing a complete version of Quartus just for the drivers should download the Quartus 11.1sp1 stand alone programmer from here: https://www.altera.com/download/software/prog-software/11.1sp1 ...though it does take up roughly 800MB once installed!! Otherwise use the attached drivers --- Quote End --- Works like a charm! -Uninstall the old driver on USB blaster (also select Delete driver software) -Remove the old drivers folder and copy the folder extracted from the zip -Reinstall the drivers and you are good to go! Thanks chnaideur!
