14 years agoUSB blaster installation problems in W7 64bit
:confused: How can I install USB blaster in Windows 7 64 bit? it just can´t install the drivers correctly, every time I connect the tool to my PC it tries to install the already installed drive...
14 years agoI'm also using Windows 7, 64 bit, and none of the driver packages work for me. Maybe it's because I use a terasic Byte Blaster.
When I point to the driver directories, Windows complains that the drivers are not digitally signed. Windows 7 generally refuses to load unsigned drivers. Does anyone have the same problem?
