14 years agoUSB blaster installation problems in W7 64bit
:confused: How can I install USB blaster in Windows 7 64 bit? it just can´t install the drivers correctly, every time I connect the tool to my PC it tries to install the already installed drive...
14 years agoTurns out my problems weren't completely solved either. The Quartus programmer worked, but the development kit software didn't. The development kit stated that its version was 10.1, so I downloaded the stand alone programmer 10.1 from ftp://ftp.altera.com/outgoing/release/ and now it finally works!
monnoliv, check the version of your MAX V board test system and download the associated stand alone programmer to get the right drivers. Otherwise, the attached drivers are of version 10.1 if you would like to try these instead...
