USB Blaster II Trouble (no Nios II taget connection pathes were located. Check..)
- jjang7 years ago
Hi. @AhmedH_Intel Already Checked..
Ignore mismatched system ID.
Ignore mismatched system Timestamp
and.. without Marking.. .. "System ID Checks" .. Mark or didn't mark. ,
When "Click Refresh Connections", Have to shown somethings at "Connections→Processors Some.."
checking System ID is Next Step.
1, sof
2, refresh connections -> "Connections→processors"
3, Select preocessor, if you are Multi Processor..
4, Byte Stream Devices → Select , if you add more than 2 "JTAG UART"
5, then Mark, un-Mark System ID..
In my case using "PL-USB2-BLASTER" Below Pics.. "Refresh Connections" click more than 10 times , and Resolve Names. clock lots of times..
but doesn't works. just Error message
→ "no Nios II taget connection pathes were located. Check connections and that a Nios OO .sof is downloaded"
