Updated Blaster Not Working
- 7 years ago
The cause of the problem was found. It was the frequency of the USB Blaster.
The Quartus II software comes with drivers for the USB Blaster, but does not allow for changing the communication speed of the Blaster.
The Quartus Prime software does. The default value of the speed is 24 MHz, and the devices we were trying to program worked at a lower frequency. Once we changed the frequency of the USB Blaster to match the devices, it worked fine.
Hello Vicky,
Thank you for your answer. Unfortunately I have already done those steps. That is what I did to get the driver for the USB Blaster, so the software recognizes the USB blaster is connected. The problem is that device chain is not being recognized. The quartus software says that there are no devices in the chain.
If I connect the DUT to the older XP system with the parallel port byte blaster, it has no problems seeing all of the devices in the chain.
