Anvin_T_Intel
6 years agoUnknown device on connecting Stratix 10 GX Development Board through USB, also not detected by board test gui software
We have tried connecting the Stratix 10 GX Development Board through the USB port but Unknown device is being shown. So tried connecting with the JTAG port using USB Blaster II with which the Quartu...
sstrell
6 years agoI'm not sure why you're trying to program the MAX V device. If you're not seeing the Stratix 10 device in the Quartus programmer, go through and check the DIP switches on the kit to make sure the device is in the JTAG chain. Try programming with a .sof file first to see if that works.
Once you see the Stratix 10 device in the Programmer, the BTS should work.
#iwork4intel
Anvin_T_Intel
6 years agoHi, Thanks for the reply.
I have made sure that the DIP switches are positioned as per mentioned in the user guide and still not able to see the S10 device (only the Max V device is visible).
Tried programming with .sof again and also JTAG issue shows up as the image shown above.
BTS gui always doesnt open by thorwing the popup error "Device not found in JTAG chain"
