SRame5
6 years agoUnder what conditions would a JTAG verification failure occur?
We are using 2 Max 5 devices in our board, identical part numbers 5M2210ZF324 with similar board designs for each device. While we are able to program one of the devices successfully, we are getting...
a_x_h_75
Contributor
6 years agoThis is all pointing at a signal integrity issue. Whilst the trace lengths you specified aren't a problem I'm concerned that the adaptor you had to make is contributing to the problem.
Can you make an active adaptor board? Buffer the signals from the Blaster onto the target. That'll help. Buffer TDO back to the Blaster as well.
Are you using a genuine USB-Blaster?
Cheers,
Alex
