ymiler
Contributor
2 years agoUnclear synthesis message
Hi My Quartus Prime pro version is 22.3 I get no clear error message in Analysis & Synthesis step : The following tri-state nodes are fed by constants : The node ; 13032:13033 ; ; The following ...
SyafieqS
2 years agoHave you able to locate the node? and then cross probe to rtl?
ymiler
Contributor
2 years agoI found the issue, there were two assignments to same wire ( 1 in RTL and the other through XMR )
Quartus message was unclear - the node had a different name then Quartus indicated.
