TTetz1
7 years agoUnable to run BTS on Stratix 10 GX Development Kit
Trying to run the BTS (Board Test System) as an initial step with this board, dev kit is "stand alone" with jumpers in factory config. Attached to machine with fresh install of Ubuntu 18.04 Compile...
AR_A_Intel
7 years agoHello
Welcome to INTEL forum. Could you tried with Quartus 17.0ir3.0.182 and before you begin, could you reconfirm again step to run the board test system. Refer to link on 6.2 running the board test system https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug-s10-fpga-devl-kit.pdf
TTetz1
7 years agoI installed version 17.0.0 Build 290. I do not see any way to download 17.0ir3.0.182 -- do you have a link for that?
I re-ran using the steps from section 6.2 in the user guide (same document that you linked).
The error messages and behavior of the BTS GUI are the same as the file I linked before -- so it still doesn't run. (System Information is empty, trying to configure with any image dies after 1%.)
