Unable to read file u-boot.scr
- FawazJ_Altera
Hello hhshsh,
Would you let me know how did you create this scr file?
I have seen this issue before, and it was due to my wrong compilation of the txt file to scr. I did modify the original scr file and made it unreadable.
The script file u-boot.scr was obtained with the following procedure
1. On host PC, create text file u-boot.txt with the following contents:
fatload mmc 0:1 $fpgadata soc_system.rbf;
fpga load 0 $fpgadata $filesize;
run bridge_enable_handoff;
run mmcload;
run mmcboot;
2. Add the U-boot header to the u-boot.txt script file to create the
u-boot.scr file:
$mkimage -A arm -O linux -T script -C none -a 0 -e 0 -n "My script" -d u-boot.txt u-boot.scr
3. Write the file on the SD card.
please let me know if this can help. If not, I can send you a sample scr file.
- KhaiChein_Y_Intel
Could you explain in details? Is there any error messages?
