NLewi3
7 years agoUnable to program my .sof file into the Stratix10 Development Board.
Programming my design.sof onto the Stratix10 Development Board the Progress Bar stops at 9% and I received the following 3 messages: "Device has stopped receiving configuration data 18950." "Error me...
YuanLi_S_Intel
7 years agoHi Nik,
This might be due to on-board switches or programming cable. Are you using USB Blaster II? If it so, can you try to change the cable's TCK frequency to 6MHz in Quartus Programmer? Also, can you try to change all the switches to default position on the board?
YL
NLewi3
7 years agoAfter further investigation I am able to load the ‘btsd_config.sof’ for the Stratix 10 Development Board. However, I am unable to generate a .sof file that I can load into the Stratix 10 Development Board. I have a very simple design, an input clock driving a counter which is attached to some output LEDs. The .sof that is generated stops loading at 13% and the error “Device has stopped receiving configuration data. Error message received from device: Device is in configuration state. Operation failed”.
I am at a loss as to what the problem could be???
Nik
