Raghuttam
1 year agoUnable to install BSP using aocl install
I have a BittWare A10PL4 board containing Arria 10 chip on it. I received the BSP from BittWare and tried to install it using `aocl install` and this is what I received. Do you want to setup the F...
BoonBengT_Altera
Moderator
1 year agoHi @Raghuttam,
Thank you for posting in Intel community forum and hope all is well.
Unfortunately as the BSP are coming from BittWare and we have limited understanding and access to that, hence it limit us from further checking. However we would try our best to look into the situation, but as the final resources, you may need to contact BittWare support.
Would recommend the following:
- Could you run a aocl diagnose to check on the OpenCL platform setup/settings just to be sure.
- Perhaps also uninstalling the mention bsp just to get a clear start
- Is this limited to just to BSP or were there other BSP successfully installed?
Best Wishes
BB
