NLewi3's avatar
NLewi3
7 years ago
Unable to generate a loadable .sof for Stratix 10 Development Board
I am able to successfully load the Intel provided ‘btsd_config.sof’ for the Stratix 10 Development Board using the Quartus Prime Programmer.
However, I am unable to generate a .sof file that I can load into the Stratix 10 Development Board. I have a very simple design, an input clock driving a counter which is attached to some output LEDs. The .sof that is generated stops loading at 13% and the error “Device has stopped receiving configuration data. Error message received from device: Device is in configuration state. Operation failed”.
I am using Quartus Prime 19.1.0 with patch 0.03
I am at a loss as to what the problem could be???
1 Reply
  • JohnT_Altera's avatar
    JohnT_Altera
    May I know what is the configuration setting are using on your Quartus project? May I know what is the blaster you are using? If you are using blaster II then could you try to reduce TCK clock frequency?
