RK
7 years agounable to debug uboot in arria10 soc
Hello We tried using board design example available "A10_FPGA_to_HPS_Bridge_Design_Example" from "https://www.intel.com/content/www/us/en/programmable/support/support-resources/design-examples/soc/f...
PZhan12
7 years agoHello,
I have a similar problem in debugging uboot in arria10 soc. When I connect my Uboot debug to the SoC Target, I got this:
Error(CMD16-TAD59-NAL18):
! Failed to load "u-boot"
! Download of 149,528 bytes to address S:0xFFE00000 failed while writing block of 4,096 bytes to address S:0xFFE00000
!Bus error on memory operation.The .ds file I use is generated automatically by BSP Editor:
# Copyright Altera 2015
# All Rights Reserved
# File: uboot.ds
# stop processor if running
# and then reset processor
stop
wait 5s
reset system
stop
wait 5s
set trust-ro-sections-for-opcodes off
# Load uboot elf
loadfile $sdir/uboot-socfpga/u-boot 0x0
start
wait
restore $sdir/devicetree.dtb binary &_end
# set a breakpoint on board_init function
tbreak board_init
# tell target to continue executing
continue
# wait for breakpoint
wait 60sBest wishes.
FawazJ_Altera
7 years agoHello,
It looks like the debugger cannot talk to the board. Typically this happens because board is not in a good state – most commonly because Linux is already running there. I suggest to do the following things:
- Try to remove the SD card in case it tries to boot to Linux.
- Try to run the commands from the script manually one by one and see what happens.
- Try to reduce JTAG clock speed.
For reference, typically running A10 U-Boot through debugger goes like this:
- U-Boot is configured with external FPGA configuration from bsp-editor
- FPGA is configured with quartus programmer
- U-Boot is then downloaded and ran through the DS-5 debugger like you did
