17 years agouClinux and StratixIII DSP kit with TSE Marvell 88E1111
have you somebody uClinux running on StratixIII DSP kit with TSE Marvell 88E1111 ethernet chip ? Everything looks ok, but don´t work ... When i use the />ifconfig eth0 hw ether 00:07:ed:ff:4a:d7 />ifconfig eth0 192.168.1.234 />ifconfig eth0 up />route add default gw 192.168.1.254 linux report - Trying 10/HALF - in this moment i don`t know what it does ? After this i try ping to ip of my pc, it finish by request timeout (and tx led on board don`t blink). I think, that the problem is in uClinux ethernet driver, because examples of webserver (on uC-OSII) work fine and simple socket server too. Could you help me ? Thank you very much. Jan Naceradsky, Czech Reublic4 Replies
TRY 10/HALF, does it mean 10mb half duplex?
I remember you can modify the network mode in the driver file, the directory may be .../linux.2.6.x/drivers/net/dm9ks.c I don't know whether I am right, coz I am new to it,too. Good luck. - Altera_Forum
I suppose that TRY 10/HALF mean 10mb half duplex, but it doesn¨t connect eth0, because ping is unsuccesfull.
I am not sure, what could i modify in driver file - for marvell 88e1111 the recommended driver is atse.c or altera_tse.c. And the first report error during boot linux.... Jan - Altera_Forum
You can type" ipconfig" in the console to check whether eth0 is up.
If there shows the information of eth0,then it's up. Also you can check the make menuconfig--> device driver--> networking part, whether you choose the right option, for example, in the Altera DE2 board , dm9000a is the correct choice ,but not dm9000, be careful, find more information about the network part online. Or you can hear the suggestion of the following forum friends... - Altera_Forum
Hi Jan,
I'm using the same development kit and can't boot uClinux whenever I include the TSE driver support. uClinux just freezes on "Uncompressing linux... ok, now booting the kernel". If I remove the TSE driver, it works ok. Have you any hint/suggestion to make it work? Thanks mantoz
