17 years agouClinux and StratixIII DSP kit with TSE Marvell 88E1111
Hello, have you somebody uClinux running on StratixIII DSP kit with TSE Marvell 88E1111 ethernet chip ? Everything looks ok, but don´t work ... When i use the />ifconfig eth0 hw et...
17 years agoYou can type" ipconfig" in the console to check whether eth0 is up.
If there shows the information of eth0,then it's up. Also you can check the make menuconfig--> device driver--> networking part, whether you choose the right option, for example, in the Altera DE2 board , dm9000a is the correct choice ,but not dm9000, be careful, find more information about the network part online. Or you can hear the suggestion of the following forum friends...
