12 years agoubuntu boot fail on DE1-SOC
I got wrong message during boot ubuntu. and then stop on starting kernel...
U-Boot SPL 2013.01.01 (Nov 04 2013 - 19:51:38) BOARD : Altera SOCFPGA Cyclone V Board SDRAM: Initializing MMR registers SDRAM: Calibrating PHY SEQ.C: Preparing to start memory calibration SEQ.C: CALIBRATION PASSED ALTERA DWMMC: 0 U-Boot 2013.01.01 (Dec 29 2013 - 17:29:53) CPU : Altera SOCFPGA Platform BOARD : Altera SOCFPGA Cyclone V Board DRAM: 1 GiB MMC: ALTERA DWMMC: 0 In: serial Out: serial Err: serial Net: mii0 Hit any key to stop autoboot: 5 4 3 2 1 0 reading uImage 3948904 bytes read in 1328 ms (2.8 MiB/s) reading socfpga.dtb 17170 bytes read in 12 ms (1.4 MiB/s) reading soc_system.rbf 7007184 bytes read in 2354 ms (2.8 MiB/s) altera_load: Failed with error code -4 fpgaintf ffd08028: 00000000 .... fpga2sdram ffc25080: 00000000 .... axibridge ffd0501c: 00000000 ....# # Booting kernel from Legacy Image at 00007fc0 ... Image Name: Linux-3.12.0-00307-g507abb4-dirt Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 3948840 Bytes = 3.8 MiB Load Address: 00008000 Entry Point: 00008000# # Flattened Device Tree blob at 00000100 Booting using the fdt blob at 0x00000100 XIP Kernel Image ... OK OK Loading Device Tree to 03ff8000, end 03fff311 ... OK Starting kernel ...2 Replies
Did you resolve this issue. I see the same issue on this board. Based on some other threads i have tried to use dd command to copy the image myself, but the /dev/fpga0 partition is not loaded.
Regards, Gate_keeper - Altera_Forum
Check the MSEL switch at the botton of the board.
If you are booting the LXDE linux flavor, you will need to ground all MSEM pins. If you need the /dev/fpga0 to be present, you can actually boot LXDE with the other uImage, the one used in Yocto's flavor. This workaround is presented by ep1015 in this thread: http://www.alteraforum.com/forum/showthread.php?t=47258 That is what I need right now as I'm trying to run OpenCL on LXDE, but I could not manage xserver to work on it yet :( regards
