12 years agoUART (RS-232) problems with the use of Altera DE1 and FTDI UM232R
Hello. I have a problem with UART (RS-232) on Altera DE1 development kit and FTDI UM232R module. Main task is data transfer between Altera DE1 and PC through FTDI UM232R module. It is only p...
11 years ago --- Quote Start --- can you connect the oscilloscope to which ever is the TX pin of your DE1 ? If you send a single character you should be able to capture it on the scope and verify that your verilog/firmware code is working and not your terminal application or chip. Altera also has their own UART module which you add in Qsys/SOPC builder, this provides a GUI interface that you can use to just select the baud rate that you want. --- Quote End --- Hi, Have you ever used UART(RS232) qsys IPs ? Can you please comment on the below thread? http://www.alteraforum.com/forum/showthread.php?t=46325 Thanks
