12 years agoUART (RS-232) problems with the use of Altera DE1 and FTDI UM232R
Hello. I have a problem with UART (RS-232) on Altera DE1 development kit and FTDI UM232R module. Main task is data transfer between Altera DE1 and PC through FTDI UM232R module. It is only p...
12 years agocan you connect the oscilloscope to which ever is the TX pin of your DE1 ? If you send a single character you should be able to capture it on the scope and verify that your verilog/firmware code is working and not your terminal application or chip.
Altera also has their own UART module which you add in Qsys/SOPC builder, this provides a GUI interface that you can use to just select the baud rate that you want.
