Type error near ; current type std_logic_vector; expected type std_ulogic error in vhdl. How to solve this error
- sstrell
Can you post your code?
#iwork4intel
- AnandRaj_S_Intel
Hi Sisira,
The error may be due to a mismatch in vector size or operator misinterpretation.
Share your code.
Anand
- Spk00
This is my code
Library ieee;
Use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
use ieee.std_logic_unsigned.all;
use ieee.std_logic_arith.all;
entity ttcaam is
port(clk:in std_logic);
end ttcaam;
architecture Behavioral of ttcaam is
type mem0 is array(0 to 5) of std_logic_vector(0 to 5);
signal mem:mem0;
type mem1 is array (0 to 5) of std_logic_vector(0 to 5);
signal mem_1:mem1;
type mem2 is array (0 to 5) of std_logic_vector(0 to 5);
signal mem_2:mem2;
type mem3 is array (0 to 5) of std_logic_vector(0 to 5);
signal mem_3:mem3;
type mem4 is array (0 to 5) of std_logic_vector(0 to 5);
signal mem_4:mem4;
signal q1:std_logic_vector(0 to 5);
signal q2:std_logic_vector(0 to 5);
signal q3:std_logic_vector(0 to 5);
signal q4:std_logic_vector(0 to 5);
signal q5:std_logic_vector(0 to 5);
signal q6:std_logic_vector(0 to 5);
constant r:std_logic_vector(0 to 1):="00";
constant s:std_logic_vector(0 to 1):="01";
constant t:std_logic_vector(0 to 1):="10";
constant u:std_logic_vector(0 to 1):="11";
constant v:std_logic_vector(0 to 1):="-0";
constant w:std_logic_vector(0 to 1):="-1";
constant y:std_logic_vector(0 to 1):="0-";
constant z:std_logic_vector(0 to 1):="1-";
signal q:std_logic_vector(0 to 5);
signal i:integer ;
signal j:integer:=0;
signal a:integer;
signal b:integer;
signal c:integer;
signal d:integer;
signal e:integer;
begin
q1<="001001";
q2<="11-100";
q3<="-10010";
q4<="100-11";
q5<="0-01-1";
q6<="-10001";
process(clk,q(1),q(3))
begin
if(i=0) then
mem(i)<=q1;
i<=i+1;
elsif(i=1) then
mem(i)<=q2;
i<=i+1;
elsif(i=2) then
mem(i)<=q3;
i<=i+1;
elsif(i=3) then
mem(i)<=q4;
i<=i+1;
elsif(i=4) then
mem(i)<=q5;
i<=i+1;
elsif(i=5) then
mem(i)<=q6;
i<=i+1;
else
if(j<=5) then
q<=mem(j);
case q(1) and q(3) is
when r=>
e<=e+1;
mem_1(a)<=q;
a<=a+1;
when s=>
e<=e+1;
mem_2(b)<=q;
b<=b+1;
when t=>
e<=e+1;
mem_3(c)<=q;
c<=c+1;
when u=>
e<=e+1;
mem_4(d)<=q;
d<=d+1;
when v=>
mem_1(a)<=q;
a<=a+1;
mem_3(c)<=(q(0),'1',q(2),q(3),q(4),q(5));
c<=c+1;
when w=>
mem_2(b)<=(q(0),'0',q(2),q(3),q(4),q(5));
b<=b+1;
mem_4(d)<=(q(0),'1',q(2),q(3),q(4),q(5));
d<=d+1;
when y=>
mem_1(a)<=(q(0),q(1),q(2),'0',q(4),q(5));
a<=a+1;
mem_2(b)<=(q(0),q(1),q(2),'1',q(4),q(5));
b<=b+1;
when z=>
mem_3(c)<=(q(0),q(1),q(2),'0',q(4),q(5));
c<=c+1;
mem_4(d)<=(q(0),q(1),q(2),'1',q(4),q(5));
d<=d+1;
end case;
j<=j+1;
end if;
end if;
end process;
end;
- sstrell
Without line numbers or a fixed width font, it's a little tricky to figure out what's going on here, but I do see an errant space:
signal i:integer ;
I don't know if that's the issue. Does the tool say which line number(s) have issues?
#iwork4intel
- Spk00
Error is inside case statement.
ie;Type error near r,s,t,u,v,w,y,z ; current type std_logic_vector; expected type std_ulogic error
- AnandRaj_S_Intel
Hi Sisira,
- At line 85, you have used the logical operator "and" which is defined for BIT and BOOLEAN types.
- At 86 you are expecting 2bits for state "r"
VHDL concatenate operator is an ampersand (&). It can be used to combine two or more items together.
Example pad 0 in MSB.
case( 0 & (q(1) and q(3)) is
or case(q(1) & q(3)) is
Anand
- Spk00
I have checked both the cases . But again I got an error that is " Near case_expression ; 6 visible identifiers match here"
- AnandRaj_S_Intel
Okay,
Add below lines at the appropriate location and check
signal x:std_logic_vector(0 to 1);
x<=q(1)&q(3);
case (x) is
when others =>
Anand
- Spk00
Thank you
