KNaka47's avatar
KNaka47
6 years ago
TX_OUTCLOCK_PHASE_SHIFT in soft LVDS
I set "Desired transmitter outclock phase shift" of MAX10 soft LVDS setting as below,
// Retrieval info: <generic name = "FUNCTIONAL_MODE" value = "TX" />
// Retrieval info: <generic name = "USE_EXTERNAL_PLL_UI" value = "false" />
// Retrieval info: <generic name = "TX_OUTCLOCK_PHASE_SHIFT_UI" value = "49.29" />
(The above are in the generated file)
.tx_outclock
.tx_out
No change was seen in the phase relationship.
Do I need to set anything else?
thankyou​
1 Reply
  • YuanLi_S_Intel's avatar
    YuanLi_S_Intel
    Hi Kimi,
    May i know have you tried to use the LVDS generated? is it working fine?
    Thank You.
