16 years agoTwo Master RAM Access
Hi i m using NEEK and i m trying to get a hugh amount of Data from an Verilogfile to the NiosII
Now i tried to include an Avalon MM Master (Template for Burst Writing) to the SoPC that connects with the DDR-RAM, and the NIOS II Processor also connects to the DDR-RAM Templates i use : http://www.altera.com/support/examples/nios2/exm-avalon-mm.html?gsa_pos=2&wt.oss_r=1&wt.oss=avalon%20master%20template now if i start the sof file the Signaltap shows my set options, and they seem to be ok. but when i start on NIOS IDE to programm anything it always tells: Pausing target processor: OK Initializing CPU cache (if present) OK Downloading 02000000 ( 0%) Downloaded 43KB in 0.7s (61.4KB/s) Verifying 02000000 ( 0%) Verified OK Leaving target processor paused i only read with a = IORD_32DIRECT(ALTMEMDDR_0_BASE,0); printf("%d",a); ALTMEMDDR_0_BASE is the Base Adress of the DDR RAM in the system.h can anyone tell me what i have to do to access the DDR RAM with the NIOS II CPU as Master and via the Template Master that i controll via HDL??? Thx for ur help René Gärtner11 Replies
It isn't the same thing. SOPC builder will do the arbitration so that the CPU and the HDL will share access to the RAM. But you still need to tell your HDL where to put the data.
