11 years agoTTK .. having difficulties
http://www.alterawiki.com/wiki/use_transceiver_toolkit_to_measure_pci-express_link_signal_integrity Using this reference design ... I tried with Quartus 13.1 and 14.0 and in both cases after lo...
11 years agoHey Bob,
Ok, I've found a work-around. With a single transceiver link, when TTK starts, the tx channel, rx channel, and link are present in the TTK GUI. Those default links do not work. If I delete the defaults and recreate them, things work. In an attempt to understand this, I looked on the Altera KnowledgeBase and found articles stating that TTK expects the PHY at address 0 and the reconfig controller at 0x800. https://www.altera.com/support/support-resources/knowledge-base/solutions/rd07212014_396.html https://www.altera.com/support/support-resources/knowledge-base/solutions/rd07222014_165.html I suspect that deleting the defaults and re-creating the channel resolves the issue with the "assumed" addresses of the defaults. I'll change my addresses and see if the default channels work. Cheers, Dave
