18 years ago
TSE MAC on PCIe Stratix II GX dev board
Hi all,
I have a problem with the TSE MAC. I have a PCIe Stratix II GX dev board and y try to connect the TSE to one SFP in 1000BaseT. Mi problem is how obtain the 125Mhz clk_ref for the TSE.
I think is possible use one ALT2GXB to convert 156.25MHz clk_in to 125Mhz clk_out, and use this in TSE, but when i try to do it Quartus give me the error that ref_clk of TSE must be connected to a transceiver ref_clk pin.
Could some give me an answer?
Thanks in advance,
Angel Labrador
1 Reply
    Hi!
    You can open the alt2gxb in the hierarchy of quartus (after creating an instance in SOPC Builder) It's located as a sub component of the TSE. In the Megawizard which should open upon double clicking should show the expected "in" clk to the GXB. I set this to 156,25 i.e. the xau ref clock of the board you have. An external PLL will as you indicated not work so you need to feed it from a pin. I used the 156,25 without this and it worked for RX but TX failed quite naturally.
