19 years agoTroubles with the DE1 board - SD card and music player demo...
...Greetings everyone! I'm a third year computer engineering student at the University of Waterloo in Canada, and recently I've acquired the DE1 development board for my studies at teh universi...
15 years agoThat helped me a-lot to. I was having the same PIN_W20 problem on my DE1 board.
At: http://www.cs.columbia.edu/~sedwards/apple2fpga/ is an implementation of an Apple ][+ on a DE2 which I changed to work on my DE1 board. I changed the pinouts in DE2_TOP.qsf ((pinout file) I guess I should rename it to DE1) and changed DE2_TOP.vhd And now it works!!!!!. I set switch 9 to be reset. switch 0 is color/bw The lo-res colors are a-little off(unless u want more blues and greens) and also the hi-res graphics doesn't set the colors exactly correct (any two bits next to each other should be white not counting bit-7 in each byte aka palette bit) so I'll have to see about fixing that. Also something screwy on 1st byte on just a few of the hires graphics lines probably related to weird apple ][ screen memory mapping. I think I'll put a link to that apple ][ project with a copy of the two files I changed and how to fix the pin_w20 issue on my webpage: http://alumni.cse.ucsc.edu/~fkilner in a bit. Thanks for posting how to fix PIN_W20 problem :-) -Fred --- Quote Start --- Moin, Thanks a lot for the above hint! I run into the same trouble and i don't want to know, how many time i would have needed to find out myself :) Cheers, WK --- Quote End ---
