Trouble Update Partitioning in Device Tree
That's not correct, the minimal root filesystem is meant for QSPI for booting.
Thanks, but nevertheless, the answer is not quite clear(
Let me ask differently
Tell me at what point I'm wrong:
I am trying to boot from QSPI, for this I perform the actions in the following order:
1. I create a project to download from SDMMC, make a complete file system in tar.gz format, download succeeds. The full file system gives access to the QSPI and commands such as: "flashcp / mtd_debug write / flash_erase" are available to me
2. I create a project to boot from QSPI, make a minimal file system in jffs2 format, change the boot source in the BSP properties, and so on.
3. I copy the project files from pt. 2 to the memory card in a separate directory
3. I boot from the SDMMC project from pt. 1, I start to write the project files from pt. 2 to QSPI
4. All these processes end successfully
5. I switch the BOOTSEL jumper to load QSPI, reset the power and nothing happens ((
p.s. without an SDMMC memory card, I also cannot get into the U-boot console, I also cannot understand why
maybe there is some nuance that I missed, but I do not see it
grateful for any help!)
