14 years agoTriple speed ethernet on Stratix III 3SL150F1152
Hello, I want to use Triple speed ethernet on Stratix III 3SL150F1152. When using the NIOS II standard design, my simple socket server example get runtime errors. The log information is as...
13 years agoHi,
has someone rebuilt (or tried to) the project stratixIII_3sl150_dev_TSE_SGMII_v1.zip attached by yang05022? It's the first project that I've found for Stratix III that seems to work on this FPGA, but I need to write my IP address, so rebuilt it, but I don't know how to do it exactly. I'm working with the NIOS II Eclipse IDE, but the makefile seems not to work with it. I wondered that the makefile is made to work with cygwin (which I'm using right now) or MinGW, but I can't compile it because some problems are appearing. Does anyone know how to build it? Or maybe does someone know the creator of the project and the contact to ask him? Thanks!
